FliesAndFloats
- Joined
- Sep 6, 2015
- 30
2005 Maxum 2400 SD w/ Mercruiser 5.0 MPI Alpha I Gen 2.
When I purchased the boat last year the boat would warm up and the temperature gauge would run straight up and down between 170 and 180. Now, assuming the gauge is accurate, the boat appears to take much longer to warm up and only seems to hit around the 25% mark on the gauge at around 140 degrees. My thought is that I had it in the saltwater for several days at the end of the Grouper season and that maybe something got wedged in the thermostat. I want to make sure my theory sounds...umm...sound before I just go and replace the thermostat. Also, is there a recommended thermostat for this engine? I've read that mercruisers in saltwater use 140 degree thermostats to increase flow through the manifolds to help prevent buildup, but the gauge seems to indicate that something a little warmer looks "correct."
