Searay240sd
- Joined
- Jul 6, 2018
- 35
I have 2007 sea ray 240sd with a 5.0 mpi with a bravo 3 with 22p props. Engine serial number 0w661357. I recently boat the knowing it had issues. I can not get the boat above 4000. When I 1st got the boat it would go above 3500. I have changed the plugs with NGK ITR4A15, new cap rotor, wires, fuel filter, sent injectors out to cleaned. Compression in one cylinder was around 130 with 40 percent leakage in exhaust. I had 3 seats crack on the exhaust. Replaced both heads now boat had 170 psi on all cylinders. Fuel pressure is steady at 43 psi. I ran a separate fuel tank and had no improvement. I ONLY HAVE 13 INCHES of vacuum. I have no vacuum leaks. I have a tech mate its showing 100 percent power. At idle spark advance is all over the place from -2*-8*. Bost had 25* at 4000. If I turn the crank the rotor immediately moves so I don't think there is slop in timing chain. I had 13 inches of vacuum before head job. Exhaust seems to be clear, both flappers are in y pipe. Bottom is cleaned. TPS is showing 100% open 4.3 volts. Alternator is putting out 14 volts. The boat has no power after 5/8 throttle, if you give it more gas the engine does not respond. Any inputs would be appreciated. Thanks.
