Mercruiser 5.0 TBI
Boost1134
Having problem alarm does the typical 2 beeps When you turn the key on and then beeps once about every 2 to 3 seconds with engine running are not . Unplugged gear oil bottle no change , replaced tps no change . Anyone have any ideas ? . Thanks in advance
dubs283
use a scan tool to check fault codes, otherwise you can keep throwing parts at it til ya succeed
dubs283
It’s to old to store any codes
mefi will in most cases have some freeze frame codes
regardless, your engine has an active fault, i.e. the audible alarm is sounding thus indicating an active fault. a scan tool will identify this active code
i'll guess at it....intake air temp sensor fault
Boost1134
It’s a tbi old school throttle body injection
dubs283
i know, i read the thread title
tbi with a mefi controller, if you have access to a rinda scan tool or diacom you may retrieve the active fault. mefi 2/3 does have some freeze frame capability but as i stated earlier the fault is active, should be quite easy to retrieve
without using a scan tool, you may as well replace every possible sensor until the problem is corrected
still gonna stick with my guess of the intake air temp sensor fault
achris
More fish than mountain goat
What are you working on?
Make, model, year, serial number. For all we know it could be a tractor, in which case we could direct you to the Chambelin John Deer site.
Chris
iboats mod team
Thanks, comes up 1998 with MEFI-1
The lube oil bottle, over heat and low oil pressure give a constant alarm
Your beep every few seconds is on the list below
To fins out what code, you need a 12V resistor type LED or digital voltmeter with the tone function and a paper clip
Place paper clip and led as shown, turn key ON and start counting flashes. Normal no codes will flash a 12, as in Flash, pause, Fl, Fl, Fl, Fl longer pause. The cycle repeats 3 times
QBhoy
I might be wrong...but I don’t think un plugging the gear oil sensor would be a way of ruling it out.
