littlebookworm
- Joined
- Nov 30, 2007
- 574
Well, I'm finally finishing the reassembly of my 1983 5.0 GM 228 hp which is going into my SunRunner. Valve job was fine and engine looks good inside. I'm ready to reassemble the thermostat housing. The problem is the parts came out in a different order than shown in Mercruiser manual #3. When I checked the housing from the engine I had removed from the boat, it also did not match the manual. What I have is the following order: caulk gasket, thermostat, sleeve with lip on bottom, gasket, stainless space, gasket, cover. I think I should reinstall it in that order even though the manual is different. Two engines can't both be wrong, could they? Thanks for your help. Hy
