Mercruiser 5.0 vs 5.7
moosehunter74
Hi everyone, first time on here. I have a 21' Bayliner Trophy that had a 4.3 with a Alpha 1 in it when I bought it. Blew the engine on my way back from a fishing trip. I installed a 5.0 Mercruiser with a Bravo III. My question is how much would the RPS come down and would I get better fuel economy and speed if I go with a 5.7?
Here are my specs:
4.3 w/ alpha1 5.0 w/ Bravo III
rpm 4100 3700
cruise 27 29
fuel range
270 ltr tank 190 mi 198 mi
Re: Mercruiser 5.0 vs 5.7
Here are my specs:
rpm 4100 3700
cruise 27 29
fuel range
Ayuh,... Welcome Aboard,... Yer What,..??
Rpms are limited by the Prop, or Props in the case of the BIII...
If yer only pullin' 3700 rpms at Wot now, yer luggin' the motor, 'n she's gonna detonate itself to a hole in a piston....
Puttin' a 350 in it, the bigger motor, Might possibly bring it's rpms Up to where they oughta be...
Don S
It's hard to understand all you have said, but if you put in a 5.0L engine with a properly sized (gear ratio) Bravo III. It sounds like you are just way over propped. Have you tried different props? Was this engine/drive system new, or used. Have you done any engine testing?
moosehunter74
Sorry for not explaining it clearly but I cruise at 3700 and 4800 WOT. I think the gear Ratio is 2.20:1 and I'm running 24p Stainless props
Ayuh,... Which 5.0l,..?? Carbed, 4bbl., or Efi,..??
If you put more horsepower in it, you'll need to reprop to get the rpms back down...
Crusin' may, or may not be measureably better, or not...
That'll also depend on the induction system used...
moosehunter74
the 5.0 is a 2 bbl carb but i'm not sure about the 5.7
Don S
You are basically asking an impossible question to answer. But, I would venture to say, that the cost of converting from a 5.0 to a 5.7 will never be reached in the amount of fuel it would save, even at $5 a gallon.
