mercruiser 5.7 crate motor 12 yr old
jwkoehn
carbed version motor runs great @ 3/4 throttle after 10- 20 sec at wot engine pulls back 300-500 rpm has new fuel filter I suspect a weak electric fuel pump. Before I do a fuel pressure test I thought I would get a couple of other opinions
you mean your motor drops RPM after a bit of time at WOT?
first place to check is fuel pressure.
could be plugged Anti-Siphon valve
could be plugged fuel vent
depending on electric or mechanical pump........ or carb vs EFI vs MPI.......there are a few other things to look for. however first is fuel pressure
jwkoehn
fuel pres gauge shows aprox 7-8 lbs would this cause a drop of 300-500 rpm @ wot pressure checked at carb inlet fitting
Rick Stephens
7 pounds is correct. Should maintain that all the time. So next is to see if you have 7 pounds when the motor starts bogging.
You can do a test run with a hook up of an outboard fuel tank direct to the fuel pump to see if the problem is fuel delivery from the fuel tank.
