Mercruiser 5.7 engine died
ted4420
Newbie needs answers please! My neighbor asked me to look at his boat. He said it died on the lake. It is a Capri 2050SS with a Mercruiser 5.7 (looks like a small block Chevy. I will have more info. on it when he gets back home. I have tested voltage at the + terminal and have aprox. 12V. The ignition module is mounted on a brkt. on the distributor. I have read about the shift switch and would sure like to know why there isn't any spark. A wiring diagram may give me an idea how the system works. Maybe some testing procedures. Thanks, Ted
Bt Doctur
Re: Mercruiser 5.7 engine died
shorted tach, remove the grey wire fron the neg. side of the coli.
bad coil
module
dist sensor
wanna-be
1. ck the kill switch, lanyard may have gotten pulled; 2. ck wiring to kill switch; 3. ck high intensity wire to distributor; 4. ck voltage to coil (crank igntion)
ted4420
I am not familiar with boats. Where is the kill switch. There is 2 wires going to the - side of the coil. which one needs to be connected? Ted
ted4420
I have disconnected the tach. wire from the coil and cranked the motor and the motor didn't start. A few times the motor briefly started for a few seconds and then continued to crank and not start. Any ideas? How do you check the sensor and the module? Thanks, Ted
dubs283
download proper manual from adults only sticky at the top of the threads page and follow ignition troubleshooting guide. you will need a spark tester to perform the troubleshooting. the one page flow chart troubleshooting guide is quite helpful and easy to follow
ted4420
Thanks, I will look for the sticky. I did take the wires off the neg. side of the coil and used a jumper wire and briefly grounded it an saw a small spark on a spark plug connected to the coil wire. Thanks, Ted
wanna-be
"Where is the kill switch." typically below the throttle beside the driver seat.
Ayuh,.. Bump? Bump,..??
How about an Up-date,...
Did you download the manual,+ check the wiring diagrams,+ flow charts for igntion diagnosis,..??
How about the Vintage of this barge,...
With the distributer mounted igntion,.. It could be 1 of a couple...
That,... Sounds like you Found the Spark, but Flooded the motor...
Have you pulled the Sparkplugs to have a Look,..??
ted4420
I started a new post because I didn't think this one was posted. The engine starts and runs great! It than starts cutting out after about twenty seconds and the dies.I turn the key to off then try to start it again and it starts again and does the same thing. I have noticed that there are wires from the drive reservoir and 2 sensors that go to the ignition module. The problem started because of a empty drive reservoir. Tell me why these wires are going to the module. I down loaded the flow chart and the wiring diagram and followed them. Is this a engine shut down system? Thanks, Ted
can-amsledder
Because you are new to working on boats I have to ask, are you running water to outdrive while running it/trying to start it?
It almost sounds like it?s running out of gas. Fuel filter plugged??
Ayuh,... Does this barge have an Electric Fuelpump,..??
There's an oil pressure Switch mounted portside, down low, just ahead of the oil filter boss....
Try By-passing it with a jumper...
ted4420
I just started the motor, After it died, I went back and hand operated the throttle and gas squirted out of the excellator ports.
ted4420
This motor has a mechanical fuel pump.The wiring diagram apears to have sensors that connect to the ign. module. Could someone shed some light on this? Thanks, ted
Don S
Go get a mercruiser SN of the engine block just above the starter and next to the flywheel cover
That is classic electric fuel pump problem with faulty wiring or bad oil pressure switch. I know you said it has a mechanical fuel pump in the Other closed thread, but your problem can't happen with a mechanical fuel pump.
So get a SN and check for a mechanical pump again.
