Hi, I am looking for some help with ideas on how to siphon bad fuel from my tank.
Unfortunately, the prior owners of my boat replaced the floor and neglected to put an access plate where the fuel hoses connect to the tank so I can not locate where this is at in my boat without blindly cutting into the floor. I did rule out that its not located directly in front on the engine
Has anyone had success in snaking a siphon hose all the way from the filling point?
Is there any way to bypass or trick the anit siphon valve that goes to the fuel pump?
Appreciate any suggestions you may have.
Brian
Brian
