I recently got finished replacing the gimbal bearing, water hose, u-joint, exhaust, and shift cable bellows, the trim sender and limit switches, and lower shift cable on my 1989 Larson San Marino DC 250 with Mercruiser 260 and alpha one. I had a hard time getting it into alignment and after messing with it for hours, figured I had it "good enough" (not 2 fingers to insert/spin/remove, more like 3/4 fingers). The outdrive went on pretty easy, so I figured it was close enough to aligned. Well on the first journey out this year I believe my drive coupler gave out (probably on its way out anyway). I smelled burning rubber and had some smoke but no fire, temp gauge was right at 140 degrees. So now time to pull engine and inspect/replace coupler, and I will also be replacing the rear engine mounts at the same time. I already purchased a new coupler (Sierra 18-2321 Engine Coupler Replaces 12632A6), and 2 engine mounting bolt kit (Sierra 18-2141 Engine Mount Bolt Kit Replaces 10-97934A1). I am wondering if I also need to purchase the bushing that gets pressed into the rear motor mounts? (EX. http://www.michiganmotorz.com/motor-mount-p-9206.html) or does the kits I purchased include everything I need? I am hoping to complete this project this weekend.
Thanks in advance.
Also, what else should I inspect/replace while I have the motor out as preventative maintenance? I have already read to check Y pipe for rot..
Thanks in advance.
