This boat is a 1983 Sunrunner 245 with a Merc 5.7/ pre-alpha outdrive. I was running at 4200 r.p.m., no problems. Stopped the boat momentarily, & shifted to nuetral with no problems. When I shift back into forward, there is no engagment. Same with reverse. There is no obvious sign of something coming loose of the shift plate in the engine compartment. The towboat operator said he could hear it clicking like it was trying to engage, when I moved the selector. But there is not the usual solid feel when it goes into gear. I thought I smelled rubber, very faintly, so I suspected a spun prop or worse, a spun coupling. The towboat guy thinks the shift cable may just be gunked up. The boat stays in a slip and the shift cable was replaced prfessionally last year. Any thoughts? Serial 6817160, model 02608344.
