Re: mercruiser 5.7 spark plug reading result
up date here guys, as i stated before i install new spark plugs, took the boat fishing on a 25 miles round trip to the reef with four guys on board, i could only get 3600 rpm with speed up and down roughly 13 14 15 miles per on gps. carb symptom running rich smell, now here is the bad part, i went back today pull all the spark plugs, 7 plugs burning great, and again #8 cilinder that plug is white/clean plug , now i have my compression tester this time i was arm today lol. this is the result 7 cilinder read 130 psi dry # 8 cylinder only got 120 psi i put some oil in that cylinder and it goes up to about 140 psi i then give all the other cylinder some oil and re test they all stay at 130 they did not go up. so i know #8 cylinder has problem. ???? is it water, is it too much fuel, is it head gasket, does the head need to be re tork , and last with a new long block dont i sopose to be getting more compression at least 150 psi?? 130 seems a little too low,
wen i first launch the boat this season i was getting more speed, the engine seems stronger, ad at 3500 rpm i was getting 25 or 26 miles per hour with four guys on board.
you will as me what did i do wrong , all i did so far was adjust the rocker/valves and change the fuel pump, did i mess up the valve lash?? i let the engine idle loose the rockers antill it rattle then i re tighten until it stop, then i give it a halh turn tight.
HELP I REALY NEED HELP HERE thanks guys ha ha
