I just installed a new electric fuel pump in my carbureted 502, deleting the mechanical system. I need to add an oil pressure switch so the pump doesn't run with the key on and engine off. Right now the sending unit for my oil pressure gage is occupying the spot for the switch. Is there a unit that will both switch my fuel pump and send a signal for my gauge? Or is there another location I can install the switch?
Also, which switch should I order? The block is a 1995. There seem to be a few options.
