Boat is 246 SSI Chaparral 2017 with 50 hours on engine. No prior issues.
I pulled the drive for routine maintenance a week ago. I didn't touch or change the gimbal bearing, I just changed the bellows and removed the water inlet tube. The gimbal bearing spins very easily no resistance or wobbliness so I figured it should be fine. Now that I'm ready to put it back on, the alignment is off, WAY off. I dont understand how it could get so out of alignment after just 1 week.
When I pulled off the drive, it was very easy to come off, so that makes me think the original alignment was OK. If it was way off previously, the drive would have been very difficult to remove, right?
The alignment tool won't engage the splines on the coupler at all, even after using a fair amount of force.
The alignment tool also doesn't really help IMO because it doesn't show you which way the alignment is off, it just shows you that it's off somehow.
So I got a 1" plastic tapered plastic pipe which shows that the alignment is off both vertically AND horizontally. Pictures below.
The engine mounts only adjust vertical right? How am I supposed to adjust the engine horizontally?
Also, how is it possible that pulling the sterndrive off can suddenly throw the engine coupler alignment so out of position? I have never touched the engine mounts. Does the engine just sitting there without the drive for a week affect the alignment that much?
