shellone
- Joined
- Jul 18, 2009
- 42
Hi ! Can someone help me troubleshoot the following issue: I have a perfectly running Mercruiser 7.4 (serial OF 437348). Only problem is, sometimes turning the key will not start the engine, the starter will not turn, the voltage does not change (drop). It is as if I tried to start the engine while in gear. Initially it seemed that moving the throttle around the idle position would help, as if there was a bad contact in the switch behind the throttle, but now I have found it has nothing to do with the throttle and the switches therein. Some time ago I had an issue with a 5.0 V8 where the engine would start and go off after approx. 10 seconds ... it was a bad contact at a sensor for the oil pressure. Is there some sensor that might be the cause now preventing the starter to turn? Randomly, sometimes after a couple of minutes, sometimes just trying again, will start the engine as if nothing was wrong. The Key lock is OK, hot wiring there does not help, hot wiring at the relais always helps - means the engine always starts and then runs fine, with the right oil pressure and all.
