Engine info:
[FONT="]7.4 L MPI BRAVO GEN VI - L29 Serial number: 0L609594[/FONT]
So, I have had this issue the past 4 or 5 times I've gone out fishing. Usually when we fish, It's a 20 mile trip one way to the spot and 20 miles back. I've only had this issue on the return trip in the last 5 miles or so, until yesterday when it happened about 15 miles into the trip on the way out. I have not had this issue when I take my family to the beach, which is only a 5-7 mile run one way.
It almost seems as if the engine is not getting fuel for a split second, or like an injector just forgets to inject or a spark plug isn't firing. It seems completely random when it starts happening, only that it happens after longer runs (I run between 3k and 3.5k rpm). It will continue to do this every 30 seconds or so, then become more frequent until I have to pull back on the throttle because it gets too herky jerky. When I pull back on throttle, it will run fine for a while at that rpm, then begin to do the same thing. If I run at a very low rpm or at idle this will not happen. Also, not sure if this means anything, but it seems that it will coordinate sometimes when I hit a rough spot, it will "skip", but it will also do it in the bay as well. I stopped the engine when I got in the bay yesterday and let it sit about 2-3 mins, then went again and I got about 4 miles (1 mile from the marina) and it acted up again, but I was able to push through and get back. I haven't had to deal with any fuel issues or injector issues with an engine yet, so I'm not sure where to start for a diagnosis on this....I'm kind of assuming it's a fuel issue because I can't think of anything else.
Any ideas on what this could be and/or what I should do to start looking?
Thanks,
Luc
Thanks,
Luc
