ratdude747
- Joined
- Sep 30, 2023
- 298
One thing I eventually need to do on my Mercruiser 888 is swap or rework the heads so I no longer need to run lead substitute.
I may have found a deal on some heads that likely have hardened seats... they're Ford D5AE-CA 351 heads that came off an OMC 302 (supposedly includes ARP 351-302 conversion bolts). D5 indicating 1975, which is after the 1974 Ford start of using hardened valve seats.
What I don't know (and can't find) is whether or not these will run right (or rather, what the specs of the under-drilled 351 heads Mercruiser used). For most 351 purposeless they're considered junk (small valves, large chambers), but considering it had already been on a marine 302, maybe they're good for my use?
The heads are very clean and the price is very low ($50), but it's a long drive to get them... probably $250-300 total cost after gas. Is this worth it? Or am I better off to put this off for another off-season and have the original heads re-seated then?
Edit: they're wanting these gone so this is more of an "are these close enough" question. Still a lot of gas to fetch but I've drove longer for less!
