Mercruiser 888 outdrive
Status
Not open for further replies.
BobbyJ
I just purchased a 1972 Tom Sawyer with a 302 ford and 888 out drive does this have a impeller in the lower unit or just the engine water pump? this is a great old boat that has been sitting for several years. 276 hrs on it.
Bt Doctur
Re: Mercruiser 888 outdrive
There should be an impeller in the lower unit, they should be changed every 2 years.This is for raw water cooling.
BobbyJ
Thanks i was not able to locate any info on it Later Bobby
erikgreen
If you need to look things up, know that the whole system, motor and drive, was called an 888.
It's a ford 302 CI engine coupled to a "Pre-Alpha" or MC-1 drive. You'll find that most parts are interchangeable with the "Alpha I generation 1" drive but not the "Alpha 1 Generation 2" or later.
If you want to be sure exactly which parts to get when going to a dealer or looking online, use the serial number of the drive.
FYI if you need to replace the whole drive, the Sterndrive Engineering SE-106 will bolt right up.
It's pretty easy to get parts.
Erik
Haut Medoc
Yes, it has an impeller....
Everything stated above is correct....
You can download a free manual for your engine if you go to the 'adults only' at the top of this page....;)
Welcome to iboats, btw....:)
Status
