MerCruiser 888 shift interlock adjustment and operation
IBDilbert
Very curious on how the interlock is suppose to work. My engine use to momentary stall when shifting from neutral to forward or even neutral to reverse. I don't remember if it use to stall coming out of gear, but it may very well have. I have since replaced the lower shift cable.
What I have noticed is it no longer stalls when going into gear from neutral, and sometimes makes a grind.
So what are the normal operations of the interlock, is it only suppose to trip the switch when coming out of gear when there is tension on the cable? As far as going into gear, I assume nothing syncs the gears, you just need to be quick?
Bt Doctur
the shift interupter ONLY activates under load, in the water with a load on the prop coming out of gear . Any other time you need a new lower cable or have corrosion some place
IBDilbert
Nuts, wasn't sure where to post it, and it doesn't look like it will let me delete it. I will make a copy over in the merc section, when an admin sees this, please delete the thread.
Sorry and thanks!
-Tim
