DC20
- Joined
- Dec 5, 2007
- 361
Ok, second time out ever on the new to me boat. 2005 300 MAG MPI (0W3404402) with Bravo 3. After coming off plane to no wake zones, alarm will sound for about 1 second and engine will stumble (once it did stall but started back up immediatly) . I watched the gauges each time, temp good, oil pressure good. Drive lube is full.
Engine has had oil, filter, fuel filter, plugs, rotor, cap, sea water impeller, thermostat. The fuel is maybe 3 weeks old, I did add Mercs new Quickare to the fuel before going out this am. It did not do this the first outing, the thermostat was changed out after the last outing as well.
Your thoughts???
Your thoughts???
