acdc96
- Joined
- Apr 23, 2013
- 412
I need to service my alpha 1 drive to replace: Bellows, Gear Case Oil, impeller, and a couple of other things. i have not serviced the drive in a couple of years cause i have not used the boat. I've only changed the gear case oil and the impeller once since I've owned the boat. I've never taken the drive off and all the "How To Videos" are on the alpha 1 gen 2 drives.
I've made a "contraption" to hold the drive while taking it off. Here are my questions:
How much gear case oil/lube do i need?
On some of the videos their is a gear oil monitor inside the boat [on the engine] but my does not appear to have one?
The kit I'm buying comes with a Gimbal bearing. do i need to replace it? will it require taking the drive apart more?
The kit I'm buying comes with the following: Bellows for u-joint, Bellows for exhaust, Bellows for shift cable, 3/4 hose, 5/8 hose, Gimbal bearing, and various O-Rings and gaskets. [I've including a pic of what comes with it]
What are the 3/4 and 5/8 hose for?
1987 Mercruiser 260HP V8 with a 1987 Mercruiser Alpha 1 Gen 1 drive
the photos of the drive are old and the drive looks a lot nicer now then in the photos. i can upload more photos if needed
thanks in advance
thanks in advance
