Chemdawg
- Joined
- Aug 31, 2013
- 112
Hello everyone. I have a question. My boat has an 87 3.0L Mercruiser with alpha one outdrive. Gen 1. This last summer the gears in the upper unit went bad. I puled it apart and cleaned out the upper case, and had the lower case rebuilt, by my local shop. I noticed some dings in the upper half that I wasn't happy with and was going to purchase a used unit that was at the shop. However, I know my unit has 20/24 gears for 1.94 ratio. This unit is a 1.84 ratio. Will this still work with my lower? I know it will change the ratio a bit, but will that make a big difference? It's an SEI upper unit in really good shape. I'm just not sure if it's a bolt on setup to my lower unit or if that gear ratio is too far off for my 3.0L.
Thanks in advance.
Pat
Thanks in advance.
Pat
