My 1996 5.7L Mercruiser Alpha One seems to slowly lose gear lube. This seems to have started since I changed the lube at the beginning of the season and I've put barely 7 to 8 hours on it since then. The fluid in the reservoir is normal color. It seemed to not take the full specified amount when I was pumping lube back in....could there be something simple like an air bubble? What should I check?<br /><br />I posted a thread here last week about this same unit "slipping". Replaced the prop and hub this weekend and that problem appears to be gone. Could these situations be related?
