mercruiser beeping
penguinsfan
hello i'm new to boating i just got my first boat and went out today. its an 1995 sylvan with a mercruiser 4.3. today when i took it out it was making a lout beeping noise. it was just a long beep not beep beep. it did go out after about 5 minutes but it was annoying. now i did notice the oil pressure guage was up to almost the max i think 80 ?. and also my boat wouldn't go in reverse.
thank you
Re: mercruiser beeping
thank you
Ayuh,... Welcome Aboard,....
For that vintage, I believe the alarm sounded for High water temp,...
Low oil pressure, or low oil level in the drive's oil bottle...
It could be any or all three, or their sender/ switches...
My 1st guess on the reverse is the lower shift cable needs changin'...
penguinsfan
i checked a little closer today and i noticed that the drive oil resevoir container was completely empty and there was a small other plastic container on the right side was only half full. could this be the problem ?
thanks again
CStradling24
thanks again
Absolutely.
spdracr39
Its also important to mention if the drive oil reservoir was empty the oil went somewhere. It should not go down unless there is a problem. You need to have the drive pressure tested and get the leak fixed.
penguinsfan
ok i did an oil change and all is well no more beeping so that was it. it was probably just low but i did a whole change so now i know. :) I did notice when i was looking at the motor there is a vent looking hose that is broken. its pretty thick rubber looks like some kind of venting hose. is this a big thing to be worried about or should i change it and is it a do it yourself kinda thing for a newbie like me.
thanks alot guys
