Hi all,
I'm in the process of repowering my boat with a longblock from marinepowerusa. I have a couple of questions about this new motor, and I need a response from the people who didn't sell it to me
First concern is the cam. Original engine is a 1993 5.7L Bravo engine (I can get the s/n if anyone needs it) that came with a roller cam. The new motor has the roller block, but it has a flat tappet cam. My concern is that this motor won't match the power output of the other engine, which is a low hour MerCruiser motor with the correct original roller cam in it.
My other related concern is the distributor gear. I don't know Chevys, but with Fords you cannot use a distributor gear from a flat motor on a roller cam and vise-versa. It shreds either the cam gear or the distributor gear, depending what exactly you do. I called their tech support and they assure me neither of these items are a problem but I'd expect that response from someone who just sold me a motor. I just want to be sure I'm not setting myself up for a huge failure that will somehow get blamed on me, and cause the warranty to be voided.
