Mercruiser Charging System
jasmo123
Hello, I have enjoyed reading the forums here and have gathered lots of valuable information about my boat and engine.
I have a 1997 Mercruiser 3.0LX Alpha I S/N 0K--- Electronic ignition. I recently found my volt gauge under the panel and cut a new hole to mount it. Now I am getting worried. The volt gauge shows almost 16 volts when the engine is running. Shows a little over twelve when not running. My question is how much voltage is too much? I am going to check probably today with a Digital Volt meter to see exactly what the voltage is. Also, if my connections are good could a weak battery cause this high voltage situation? (I ran the battery dead a few weeks back and recharged but it never would show a green eye anymore, but starts the engine fine) The boat runs great so what damage might I do if I keep running this way? Is there an adjustable regulator? Sorry so many questions but this has been bugging me. Thanks.
tysonnathan
Re: Mercruiser Charging System
should be b/t 13 and 14. check it with the digital guage to be sure it is an accurate reading. if the reading is correct, could be a bad voltage regulator, which is easy to replace. constantly overcharging will kill the batry...
jasmo123
Well, I had a chance to check the voltage at the battery this evening with the engine running. The voltage at the battery is 14.65 volts with a digital volt meter. I checked the Mercruiser manual and it says the voltage should be between 13.9 and 14.7 volts. So I guess my boat volt gauge is just reading high. No too worried about the gauge as long as the voltage at the battery is ok. I wonder if anyone knows if these gauges are adjustable? I do not know what brand gauges they are but I will investigate this the next time I have a chance. Good Boating to ALL!! :D
