mercruiser control need help finding part
Hello Boaters
I need help finding a part for the control box on my boat it is the throttle only push button it is the mid 80s square type
it seems I cant upload photo so here is a pdf showing the control it the first on when you scroll down thanks.............
  • ELECTRIC WIREING.pdf
Fun Times
Depending on style, it seems there are two part numbers for this button.....85896 or 88149...I "believe" you may need the first number which would be this one in the following link which has some photos of the button you may be able to match up with, http://www.ebay.com/itm/Mercury-Mar...ash=item33ca61fe8e:g:TwQAAOSwTM5Yxt0u&vxp=mtr
Both numbers are coming up as no longer available. Search mercruiser Remote Controls & Components > 1986 - 1993 Remote Control Assembly (With Power Trim),
Item number 18, http://www.mercruiserparts.com/bam/subassembly/32078/1989/50
Item number 20, http://www.mercruiserparts.com/bam/subassembly/32078/1989/90
Hope this helps some, good luck.
