Scarborough
- Joined
- Sep 25, 2011
- 42
Hi,
I have a Mercruiser 2001 5L MPI, raw water cooling and with about 800 hours on it,
We have been out for the day and all seemed to work fine, except for the engine temp gauge was not showing any temp at all and we didn't get any hot water to shower in. Only reason why I didn't turn back was because I also have a Northstar GPS with Smartcraft installed and it told me the engine temp was fine, no overheating alarm either. What I did notice during the trip was that the temp gauge momentarily came back and at the same time Smart Craft indicated the water pressure increased from about 10 to 15/18psi then back again to about 10 when temp gauge showed no reading.
When we got back I pulled out the boat and flushed the engine as usual but this time the overheating alarm sounded and I turned it off. Note that Seawater pump and circulation pump has both been recently replaced (Seawater pump because the impeller broke and the housing was in bad nick). During the flushing of the engine the water is come out equally no problem from both sides.
I assumed that it was the thermostat which I changed but I still have the same problem. Can I just have been unlucky and bought a faulty one (bought it from a Mercruiser dealer and it was a stainless steel one)?
3 questions:
1 ? Why is it overheating during flushing but not running (the water supply has always been enough before to flush it)?
2 ? Any idea on why we first lost engine temp gauge and hot water?
2 ? Where does the Smartcraft temp sensor sit?
Cheers,
Scarborough
3 questions:
Cheers,
Scarborough
