+1, There are many options for greases but for a job done right it's usually best to stay with something that is recommended for the components you're working on. Mercruiser used to make this an expensive challenge as you had to buy many types of greases for different areas but they have just recently came out with a better grease that is more of a one grease handles most everything specification wise.Here's the thing. PROPER marine trailer wheel bearing grease is clay based, so strictly speaking, no don't use it on the splines. However, as most people use non-marine wheel bearing grease in their trailers, use that for your splines.
