Mercruiser Distributor Cap replacement 5.0L 1999 thunderbolt
afirststep
First time replacing replacing distributor cap on a Mercruiser 1999 5.0L 305CID with Thunderbolt ignition.
I followed the markings on the distributor cap for the wires. I used the REV markings and looking from the top of the cap, the firing order is 1-8-4-3-6-5-7-2 reading counter clock wise.
The engine did not start. I looked in the manual and the manual shows a clockwise rotation with the same firing order. It also shows the #1 cylinder on the left. So the diagram must be looking from the top?.
I am confused. Which is right the cap (CCW rotation) REV markings or the Seloc repair manual diagram (CW rotation)?
Wife dumped the old cap and rotor (looked like a spider!)
What am I doing wrong?
Thanks, Andrew
Re: Mercruiser Distributor Cap replacement 5.0L 1999 thunderbolt
Ayuh,.... Welcome Aboard,... Why'd ya do that,..?? you Don't have a reversed motor,.....
afirststep
The cap on the carb says left rotation, so I followed REV.
Do I use the STD or REV markings on the cap? The diagram in the book follows the STD markings. You seem to agree with the STD markings.
Just trying to get things right or is it left?
Thanks,
Andrew
Thanks,
Andrew
Ayuh,.... Left-handed rotation, is Standard rotation, from the workin' end of the motor....
afirststep
Duh, why did I not think of that!
Megga Thanks!
Andrew
