I have a Mercruiser Alpha One Generation II 1994 drive.
Yesterday I pulled the drive to install a new shift cable bellow, cable, and exhaust hose. The gear was in forward. Today I went to install the spline shaft into the housing and drive. It would not go in for anything past the bearing. Are there any tricks to this?
Side note I could not turn the spline shaft by hand and turning the prop does not move it either. Some manuals said to rotate the prop CW to align the splines. I have not per the manual re connected the lower shift cable at the engine.
