Mercruiser engine driven seawater pump compatibility.
thumpar
The original seawater pump on my boat was the multi piece housing type and has been converted to the one piece plastic type. I am looking to get an extra impeller to carry on board in case. Are the impellers between the two the same?
HT32BSX115
Re: Mercruiser engine driven seawater pump compatibility.
I *think* they are the "same' but if I was going to try to use one, I would check the part numbers to be sure.
Mercury Mercruiser engines and parts
Regards,
Rick
thumpar
In case someone runs across this thread later, they are the same. I looked up part numbers for the impeller itself between different housings and they are the same. Now I have my spare on board.
Fun Times
thumper, As you now know they are the same. The later/newer model brass impeller housings use a different impeller part number though. The shaft size on the later brass models is smaller then your older model pump.
HT32BSX115, knowing you have the Hardin marine stainless water pump on your boat now, you would utilize the same impeller as thumper. Part number 47-59362T1.
