Re: mercruiser engine starts but stalls
I just went through that, I would suggest takin a sample of the gas. I found mine to be a nice disgusting cloudy color. If that is the case drain your old gas and put in a fresh tank of gas. After that, make sure you timing is set properly, idle is set properly, and your idle mixture is set properly if you have a carbed boat.
I run my idle at 600-700rpms.
To set your idle mixture is easy. Once you get the boat actually running at idle, go ahead and set your idle speed. Get out a small flathead screwdriver and turn the idle screw to the right nice and slow until the engine starts to stutter and immediately go back to the left. Once you reach a point where it stops stuttering turn a half a screw to the left and leave it for now. Check your idle speed again to make sure it is holding. If it stayed where you want it you are done, if not adjust the idle speed and than you are done. Enjoy!
