Mercruiser Exhaust Pipe Identification
20pilot
Coming off my Manifold/Riser I have a down pipe. I replaced the manifolds and risers about a year ago, but not these pipes because I could not locate them. Of course, one of them developed a pin hole so I would like to replace both. Its on a Mercruiser 350 Fuel Injected. Attached are a couple pictures to help identify the part.
Thanks in advance.
Thanks in advance.
Appears to be an inboard, have a serial number (best) or the year?
20pilot
Unfortunately, I purchased the boat used and have been unable to find a serial. You are correct this is a inboard engine on a Fish Nautique. If I had to guess the year I would say late 90's.
Bt Doctur
I believe some 3 inch wet exaust and some copper or fiberglass 90 degree elbows should work.
looks to be a double 90 and they are aluminum, heli-arc??????
