Mercruiser "flat rate" labor schedule
Status
Not open for further replies.
Pete104
In particular I'm looking for transom section. Both Alpha & Bravo.
As I recall, the shift cable & bellows is not part of the u-joint, exhaust & water hose party. So what I would like to find out is, how much time do they allow for, #1 shift cable & bellows, #2 u-joint, exhaust & water hose on both models!
Thanks
Fun Times
Re: Mercruiser "flat rate" labor schedule
Transom Assembly
Transom Assembly
Part Code Transom Assembly Flat Rate
Code Alpha Bravo All X, XR, XL UFO Failure
Mode Description
203 Bell housing MT21 4.0 3.5 3.5 03 Incorrectly
assembled
203 Bell housing—shift shaft MT22 1.5 ‑ ‑ 04 Bearing spalled
501 Exhaust bellows MT23 1.5 1.5 1.5 07 Broken or cracked
506 Exhaust tube MT24 0.5 0.5 0.5 12 Corroded or pitted
212 Gimbal bearing MT25 1.5 1.5 1.5 25 Machined incorrectly
213 Gimbal housing MT26 8.0 8.0 8.0 31 Seized or Stuck
227 Gimbal housing assy transom
gaskets or seals MT27 6.0 6.0 6.0 –
235 Gimbal ring, swivel shaft or
steering lever MT28 7.5 7.5 7.5
228 Inner transom plate MT29 5.0 5.0 5.0
221 Shift cable MT31 3.0 3.0 3.0
235 Swivel pin seals, bearing or
bushing MT32 6.5 6.5 6.5
230 U‑joint bellows MT33 3.0 3.0 3.0
‑ Diagnosis or test MT34 0.5 0.5 0.5
235 Electronic steering indicator MT35 0.5 0.5 0.5
112 Trim limit switches or sender
leads MH34 2.5 2.5 2.5 2.5
Status
