littlebookworm
- Joined
- Nov 30, 2007
- 574
Before dropping my 1983 5.0 into my boat, I wanted to run it on the dolley. My plan is to use a set of gauges from my old boat mounted on some plywood and connected to the engine harness via a used boat harness connector. I picked one up at the local marine salvage yard which fits perfectly. However, it's numbered differently. Instead of 1-8 in a clockwise circle with 10 inside the circle, it has 1,2,8,9,6,5,3,7, and 4 inside the circle. The color code is also not exactly the same as the engine harness but that doesn't matter since it's only a test set-up. I can't find that wiring sequence in the Mercruiser manual. Is it from a newer engine or possibly a Penta? I've made up a conversion chart and am wiring it accordingly. Hy
