Mercruiser head gasket replacement
flournoyg48
The oil in my 1996 bay liner keeps getting water in it so I’ve come to the conclusion that my motor is cracked or I blew the head gasket. Praying that nothing is cracked I’m going to attempt to change the head gasket. Have the gasket shapes changed any over the year or can I buy any 3.0 head gasket?
Ayuh,...... Define Any 3.0l head gasket,.....
matt167
1991 and later I’m pretty sure. You will want one for marine use. They were never used in cars but they were used in fork lifts
nola mike
There are other causes of water in the oil
flournoyg48
Yeah but I figured blown head gasket would be the best scenario. I found out other reasons would be like a crack in the motor or the manifold so I’m going to replace the head gasket and if one of those is the reason I’ll more than likely find out when I take everything apart
Dillusion808
Manifolds seem like a way better first option than just tearing apart the head to change a gasket that may not be leaking.
Ayuh,..... Pressure test the cooling system, then you'll know, without wasting yer time, 'n money,....
tank1949
do compression test FIRST! If good compression, figure you will have to pull and examine engine and/or replace it.
