Ayuh,.... Where'd ya find it,..??
What do ya know 'bout it,..??
What size is it,..??
If it came off a 4.3 Volvo, then it will work on a 4.3 Merc. Does appear to be a Merc heat exchanger. Unable to find a 90's model closed cooling system online to check part numbers, but later 4.3 used part number 864395T01
Thanks for the info, so can i use this on my 1990 Merc 4.3?
If it came from a 4.3 (or larger motor), and if there is noting wrong with it the IMO yes it should work. I'm just looking at a pic.
The Merc web site shows the dimensions at weight 35.20, length 32.5, width: 14 and height: 12.88
http://www.mercruiserparts.com/864395t01-heat-exchanger
Only other question is this would be installed on a newly rebuilt motor?
Being under 300 hours is rolling the dice. My memory is not what it use to be but I think it's under 20 hours for conversions
ok, why is that? Does it matter that it was only used in fresh water?
The reason behind it, is ever motor builds rust inside that doesn't have antifreeze in it. It will pick up sand, mud or over things also as it is operated. The little bit od build up in a raw water cooled motor is of no concern. As some of it breaks loose it just goes out the exhaust. Closing up the system will keep any of the crud in the motor and will collect on the thermostat, heat exchanger and other areas.
So it may need to be drained and refilled every so often if issues show up. Salt water motors are worst then fresh, might even be 20 hours for salt and 50 for fresh. I can look around and find it but the note is it is less then 100 in any case.
You can do it, just most all do not recommend it. Maybe some others can comment.
Found it on Craigslist.
It came out of a 2006 Volvo 4.3.
I don't know the size, but i think its 5x21.
How much did it cost? If you don't mind me asking.
Iam kind of in the market
I got it for $150.
Kind of got it right after the posting went up.
