jimmywayne
- Joined
- Aug 2, 2006
- 38
Hi everyone Im restoring a 86 searay seville It has the 3.0 mercruiser alpha one outdrive. Im restoing the boat and im too the point of glassing in a new front mount. I failed to measure where the old holes were at when i tore the hull down for a rebuild. i got the transom done and the inner transom plate bolted on. Im gonna be ready to set the motor in. I realize alignment can be adjusted up and down but i dont see adjustment port and starboard. what my question is how do i find out where to drill the holes for the new mount Should i drill the holes with the engine in the boat and align it before i drill the new holes? or whats the best way to drill the holes in the correct spot in the motor mount. My idea was to run a string line in the center of the gimbal bearing and run it to the center of the bow of the boat and put the center of the front engine bracket (the bracket that adjusts up and down) on the string line. any ideas?? any information would be greatly appreciated. Thanks Jimmy
