Mercruiser I/O Welch plug installation
Bud420x20
Instructions on the correct installation of a welch plug on the I/O? What do you guys use to install them? I installed this new one and it floated around until the permatex dried. I assume it's supposed to be a tight fit. (Photos attached, #5 on the schematic)
I use hi-tach sealant and a socket which just fits inside the plug. Attach extension and drive it in, then remove. The socket keeps the plug from bending inward to far and makes a tight seal. If done right the socket will need some pulling to remove
Bud420x20
Best way to remove the one I just installed incorrectly?
Flat blade screw driver on top or bottom (your choice) and hit it with enough to pitch it in. One side will go in and the other out, then grab with pliers and pull.
Hit it with a small blow and keep increasing a bit more until it moves. Screw driver goes inside plug, not on edge of it. Don't want to score the opening
Bud420x20
Just to clarify. You guys are talking about the plug on the outdrive. Correct?
First I am assuming the plug was installed cup edge facing out, and you said its loose
And I'm talking about this plug your pointing at, pics not that clear
Bud420x20
This used to be domed. Now it's flat-ish. I checked for fit in between hits.
Bud420x20
I removed it because it was not tight and upon inspection it is slightly smaller in diameter and thinner than the plug that popped out.
Ayuh,...... I didn't know there's a difference, but yer listing is an Alpha Gen.II, 'n yer drive is an MC-1,.....
Bud420x20
Bondo I don't follow. It's a 1966 mercruiser EZ shift Serial#2002201 as far as I know. All the other parts seem to fit.
Ayuh,..... I'm just Guessin' that the welch plug changed sometime over the 40 years between the MC-1s, 'n the Alpha Gen.II drives,......
You said it's smaller, 'n thinner,......
Bud420x20
Bondo It gives that part number for my specific model. You're saying they changed the part dimensions and didn't change the part number? Sorry if I'm bugging you this is the first issue I've had in a couple years with it and I wanna fix it.
Ayuh,..... 'n I said,...... I'm Guessing,......
I Don't Know,......
If it don't fit, Tightly, it ain't right,.....
Bud420x20
Bondo Any recommendation on what dimension tool to use when I attempt to install the new one when it arrives??
achris
More fish than mountain goat
Same plug (and same part number) from 1963 to 1990. And the Gen II doesn't have a plug.
The plug is designed to go into the hole, and with a tool behind it, be hit so it slays out and locks in place. You need to make a backing block to slide to the bottom of the shift slide cavity so you can 'set' the plug in place.
You also need to put sealer around the edges so it is water tight. You do not want to be filling that cavity with water! :eek:
Chris....
