Mercruiser Impeller Identification
20pilot
Hi, I have a 2008 Mercruiser 5.7. I am trying to pre order my impellers from sierra and was checking to see if anyone could tell me the part number that is needed. I am guessing since I am there I should maybe just purchase the whole impeller kit? The serial number is 1A09139. Its a Mercruiser Smartcraft DTS. Any help would be greatly appreciated.
Thanks
Re: Mercruiser Impeller Identification
Thanks
Ayuh,.... What Drive ya got,..?? Alpha,..?? Bravo,..??
20pilot
Bravo 3. just curious though, does it matter because its the impeller on the engine?
hivoltg
Yes, Some of the post-2000 Bravo's have a different impeller hub. I cant find any info with the serial number you provided. Might be a typo or something.
20pilot
hmmm. It looks correct the only thing I can think is that the A is a H. The numbers are clear... not so much the letter.
hivoltg
Merc serial numbers are usually 8, 12, 15 or 17 characters. I have tried adding a zero and other combinations with an H instead but its not coming back valid.
