Re: mercruiser lower unit leaks oil
You need to pull the drive, drain the oil and pressure test it to find which seal is leaking.
There are 2 seals in the water pump base, but if you didn't disturb them they shouldn't be leaking, however, we can all have a guess at which seal it is, but until you pressure test, that's all they would be, guesses...
Chris.......
