mercruiser lower unit
Jamz3333
When I winterized my boat last fall, I checked the lower unit grease and I don't remember it having any discoloration to it. Now I am getting it ready for summer and I checked the grease again and it is a little milky looking. What could the deal be? We had a pretty mild winterand was wonderong if that could have something to do with it?
ziggy
Re: mercruiser lower unit
how did ya do this? when i do mine, i drain it all out. the upper and lower share gear lub.
hard to say. did ya replace the gear lub last fall? imho, i'd drain all the gear lub out and reinspect it. check for metal fragments or dust on the very first part of the draining lub. then check for water intrusion (milky oil) for the rest of it. then pressure test the drive. if it leaks, find the leak and fix it. if it don't leak. fill'er up with some new gear lub and off ya go. did ya R&R the impeller, grease the ujoints and coupler? imho, this is every year maint. also..
oh, i suppose the first question should have been, what mercruiser lower unit? like a mc-1, 1r,1mr, alpha1, alpha1 genII, bravo. etc.... ;)
Jamz3333
It has the alpha 1 gen 1. Last year when i parked it, i cracked open the drain screw to check the grease ( to make sure there was no water in it ). I didnt replace the grease last year. i showed my dad and he said he didnt think it looked like there was water in it, he said he thought it looked like it was just grease that needed to be changed. he said it looked like the grease was just starting to break down. ill drain it and refill it and take it out and then recheck. hopefully im just over reacting on this whole thing.
airshot
It should be changed at the end of the year to get any moisture out before winter. Read your service manual....Why would you gamble on a 1500.00 outdrive for a couple dollar oil change?
Airshot
Don S
It's gear lube, 75W90 not grease.
