Hello,
I have a little concern here. I just bought a new boat and the guy sold it to me without the drive installed. It's a 1978 wellcraft but had the engine swap to 1998 5.7L V8 Mercruiser, but the drive was not swap. I belive I have a MC1 engine, but I am really not sure.
Yesterday I did reinstall the drive and when I was going to activate up the trim cylinder one wasn't moving. Its stuck. So I removed the trim cylindee and dismantle it to see what is the reason for it not wanting to move. I found the guiding bushing (I think it's called like that) was stuck and didn't want to move. So I removed it with a vice grip. I've put something to protect the guiding bushing but it was so stock that I had to force it intensely. I made some mark on the guiding bushing, is it bad? Can I still use it or its garbage now.
If it's garbage does anyone know a seller which sells it. Also in what chemical can I put the trim to remove grease and everything?
Also other question, I have a compartment for gear lube on my engine and the hose exit the boat via the transom and I need to connect it. I am not sure where I need to connect it. I have an idea but I'm not 100% sure if you could help me with that.
Last question, is the MC1 drive interchangeable with an alpha one?
Thank in advance I have attached some picture to help understanding what I meant.
