I need some help; I have a 1981 Glastron with a Mercruiser 470, 3.7 (224ci) liters 4 cylinder.
My boat has a bad misfire any time I put the boat under a moderate to heavy load.
If I slowly give the boat gas it is possible to get the boat on plain but if at any time while cruising or trying to get on plain quickly causing a load that engine will misfire until the engine is slowed down to an idle and a slow acceleration is achieved. I have been unable to duplicate this problem while on land.
I am a ASE Master Automotive Technician, so I have tried to address this problem just like I would in a car, first I inspected the spark plugs, distributor car and rotor, points and wires, the plugs and points were the only items to be changed, so of course I replaced the wires, distributor cap and rotor, and plugs. I have also rebuilt the carburetor due to a small fuel leak at the bowl gasket, (Rockchester 2jet). As a further attempt at fixing my misfire and making the boat more reliable I replaced the points with an Ignitor II electronic system and added a heavy duty 45kv epoxy filled coil, again no fix. I have performed many other test to try and pin-point the problem and have found no answers.
Fuel pressure is 5 psi
Adjusted timing to 8
Fuel filters replaced
New tune parts
Electronic ignition conversion and new coil
Rebuilt carburetor
Inspected plugs after boating and found to be normal
Any help would be greatly appreciated; I have tried what I can.
If you have any questions I will do my best to help
New tune parts
Rebuilt carburetor
