I have a 1988 Bayliner 2150 Capri. It had a 3.0L OMC in it. With the motor mount on the front. I have taken the outdrive off and sold it. Took the 3.0L OMC out, cause it froze ( not my doing was like that when I bought it). Got a donner boat. It had a 4.3L Mercruiser in it. I took the engine out the throttle cable, the control box, the Gimble Housing. I took everthing off this boat even the dash and all the gauges. Less the out drive it was already gone. My question is sense the motor mount was in the front on the 3.0L and on the side on the 4.3L. The supports are there for the mounts. I have the mounts on the motor that has the fluid in them. What do I need to do the the boat part to give it the right height? Do in need to glass in motor mounts on the boat side and if so what do I make them out of plywood peanutbuttered together and if so do I need to test mount the engine to get the right height then mark it and go from there? Thank You Randy
