Superjetjim
- Joined
- Jun 5, 2010
- 222
What parameters would the ECM/ECU adjust on a 4.3MPI if the thermostat was stuck open and the motor therefore running cold at around 100deg or less (rather than the usual 160ish)?
I guess it would richen the mixture, but what else like timing, reduced power as engine not up to operating temp etc.?
Also would it throw a code after a while if not reaching temp?
Thanks for your help in advance
