I had our 454 hesitate this weekend while skiing... About 1/2 hour later, we shut down, I let it sit for 30 minutes. I tried to restart. It started, had no power, wouldn't come off idle, and fell on it's face. Eventually wouldn't restart.
I raised the sundeck, had a look - nothing obviously wrong. It's MPI, so there really isn't that much to see. Nothing leaking, no obvious disconnects, throttle cables working.
I pulled the cap off the schrader valve on the fuel rail, pressed the valve in.
I got about 6 seconds of solid air.
I went through the process a few times: turn on ignition (run fuel pump), turn off ignition, bleed schrader valve, turn on ignition - until I got mostly fuel out of that valve... . Started it up and headed out.
For the rest of the day I raised the hatch just a bit to vent the motor area.
This is the 2nd MPI motor I've had a vapor lock problem on - both motors were "Mag" version - one a 350 and this on a 454.....
