I don't have the model number but have I think enough info about the engine for what is going on. It is a 2002 MPI v-8 Bravo with an ECM 555. I let it sit for a few weeks and when I came back it wouldn't start. It will crank and crank and when I let go of the ignition switch it almost sounds like it has a little kick at the end but not close enough to start. I've done a few things so far:
Batteries are good, I checked spark which is good on all cylinders, replaced cap and rotor anyway, checked fuel filters for water but there was none, checked fuel pressure at the schrader valve which was fine. Not sure what test I should do next, plus I thought I would check to see if anyone has had this happen to them, thanks.
