Justin Kennedy
- Joined
- May 13, 2011
- 62
05 Mercruiser MX6.2 b3 runs well but wot only 4500rpm. (should be around 5200) Has cool fuel with both pumps inside. Fuel psi @ 38psi. Wondering if that could be the culprit. You notice a slight hesitation from idle to wot if you accelerate hard. Not so noticable if slowly accelerate. Very slight hesitation as you move to full throttle. Holds 4500 steady. On occasion, it will die as you move to wot, as if someone turned the key off. Restarts right away. Engine sounds good but definitely not developing full power. She has about 20hours on a major overhaul. Most componentrs are new. Has an electric solenoid anti siphon valve that I have bypassed for now. Fuel is clean.
