I'm pulling the motor on an older 1988 Mercruiser 5.7L to replace corroded oil pan with a Sierra. Planning to add a few coats of additional paint (primer and top coat) and am wondering what people have found to work best to maintain the pan. Will plan to keep water out of the bilge and to clean and wipe down the pan occasionally to remove any salt and add corrosion protection coating such as Boshield or Corrosion X.
Helpful hints are appreciated especially given the labor to remove the motor to get to the oil pan.
Thanks.
Thanks.
